fuel pump help. please!
Hello I am very new to this but here I go, I have a 98 Disco1 50th anniversary. I was trying to do a cheap fix by replacing just the pump in the fuel module. I was told the the airtex e3270 would do, but then some one said that since I have the Evaporative Type Fuel Delivery System that i need the airtex e3210, I just want to make sure that when i go buy a new pump and install it that works properly. ANY HELP is greatly appreciated!!
do you have the actual pump out yet ?? If so take it to the autoparts store and compare the two of them....the difference may only be the electrical connection, the store should have the flow specs of the pumps they offer for sale......these rovers only run about 35 psi so most pumps out there would likely work...fwiw I replaced mine a few years ago with a no name pump off ebay.....cost was about $40. good luck and let us know what you find
Thank you for the info.I tried to put in my fuel pump off of a 94 GMC suburban(they looked exactly same) and the truck ran rough, looked in to it and found out that the GMC pump only runs at 12 psi. and I think that the land rover has to be at least 35 psi. Does anyone know what pump would be best?
