Fuel pump no power
Old Oct 4, 2011 | 02:54 PM
Here you go. The others will be refunded to your account. The web lackey will be dipped in recycled transmission fluid and slow roasted over old tires, and basted with diff drainings...
File Type: pdf
File Type: pdf
Old Oct 4, 2011 | 03:08 PM
Heres some shop manual pages to make sense of it all. Sorry for low res, this web site won't let you upload more than a 2 meg PDF file (says 4 GB, but it's a typo), so have to send it in 72 DPI format, one step above an oil stain.
If you like what you see, perhaps you will figure out a way to get the RAVE for yourself on your Mac. Lessons are extra.
File Type: pdf
File Type: pdf
Old Oct 4, 2011 | 03:15 PM
aerialimage's Avatar
7th Gear
Thank You
That looks like lots of great info. I will work my way through it as soon as I can and I'll post what I find. Thanks to everybody for the help!
Old Oct 4, 2011 | 05:53 PM
7th Gear
Wondering if that pdf is from the other model with relay in kick panel as the fuel pump relay depicted looks like a very simply relay with few wires. I will head over to a friends house with windows computer to try and get that rave manual downloaded. I'm surprised I only get blank pages with the Rave as I am able to download and view the other Rave manual which does not have the electrical diagrams. Also my Mac has been compatible with everything up to this point!
Old Oct 16, 2011 | 03:48 PM
bilmgl's Avatar
2004 discovery replaced the fuel pump, cranking won't start...
looks like there is no power at the fuel pump, should I trace the wires from pump?
Old Oct 16, 2011 | 06:47 PM
bilmgl's Avatar
Default fuel pump no power
2-3 weeks ago had cranking wont start, replaced CPS, and bench tested the fuel pump, started.
So ordered new pump (pump only) replaced, wont start, like there is no power to the pump. Pressed kill switch, switched yellow relay from one to another, nothing. gave up for today, planning to trace the wire harness from pump to wherever it goes, but should replace CPS again?
Please help.....
Old Oct 16, 2011 | 08:42 PM
Would suggest you start a new thread in D2 area, so you will get more attention. Also, please review this post, it covers a D2 no crank problem, has a number of download documents, etc. https://landroverforums.com/forum/di...t=crank+sensor
Travelor
Sep 24, 2015 06:11 PM
coldstart
Mar 9, 2014 07:08 PM
Sandman0306
Dec 15, 2012 03:24 PM
JumPeR04
Apr 7, 2011 09:52 PM
Michael K
Oct 3, 2008 07:42 PM
