Fuel Pump problems again
Old Jan 18, 2014 | 05:25 PM
Jon Pitts's Avatar
Default Fuel Pump problems again
95 Disco 1 3.9, runs and drives great for weeks at a time. Then all the sudden the fuel pump won't kick on when I turn the key, no start. Then sits a few days and it is fine again for a while. Is there a relay or something that is having a condition to cause this issue? Alarm problem maybe? Any help would be awesome, I have been chasing this gremlin for almost 6 months.
Thanks all for any input!
Old Jan 18, 2014 | 09:00 PM
TOM R's Avatar
I believe there is as relay, not sure what the alarm kills, there is the rollover button on firewall
Have you checked for codes?
Checked the plug at the pump/ sender?
Old Jan 19, 2014 | 12:12 AM
jimvw57's Avatar
sounds like a burned wire connection. Mine was at the plug for the inertia switch (under the hood)
Old Jan 19, 2014 | 07:12 AM
antichrist's Avatar
First step is to download the Rave shop manuals and look at the fuel pump circuit in the ETM. Best way I've found is to start at the offending unit and work your way back.
Travelor
Sep 24, 2015 06:11 PM
arthur cross
Feb 17, 2015 03:35 AM
abran
Jun 30, 2014 12:43 PM
bobmaucher
Aug 17, 2011 12:59 PM
JumPeR04
Apr 7, 2011 09:52 PM
