Fuel Pump Relay Missing or not - Fuel Pump Delivery Issue
Hi Guys, (long time no post)
My Disco, turns over, but no start.
I had a similar problem, with my disco a while back and it turned out to be the Fuel Filter - Fuel Filter is less then less then 100 hours use. (Rover is ran 2/3 times a week for less then 30 minutes each use). I am assuming the fuel filter is not the issue.
It started this morning, I went to start it, and it ran, choked, and stalled. From that point on, no start.
I checked for fuel pressure = 0
I checked for spark = Positive
I checked for sound and vibration at pump (Uncovered Pump - Felt for vibration and listened for noise) = Negative
I checked Fuel Pump Fuse (fuse box in engine compartment) = Positive (good)
I checked for Fuel Pump Relay - I searched this forum and based on Spikes responses to other posts, the Fuel Pump Relay is found under the Passenger Seat - (Blue in color) - As can be seen in the pics below, I have NO relays under the passenger seat. It looks like a PO hardwire/bypassed all the relays (I assume there are 3 relays) because there are no relays and the posts for relay mounts are empty.
Empty Relay Mount Posts
Hardwired/Bypassed eletrical wires
Questions:
1. Does it matter that the Relays have been bypassed?
2. Should I feel vibration and hear sound from the fuel pump?
3. Is my Fuel Pump Shot?
Thanks for any and all input
In Peace and Agape,
Trav...
Questions:
In Peace and Agape,
Trav...
Your fuel pump should be up under the hood, passenger side near the fuse block. Not sure but I think your year had a really large housing relay with 3 smaller relays inside that ran the system.
Hi DM,
Thanks so much for your reply -
I assume you mean my Fuel Pump Relay.
I really looked and looked on the passenger side Engine Compartment and I'm not seeing anything that looks like a relay. I've attached pics of the engine compartment. Do you happen to see the relay? Is it under the Windsheild washer fluid tank?
Thanks for your help...
Trav...
Trav...
**** UPDATE *****
Out of curiosity, after the truck had sat for 2 hours with the start problem, I decided to try it one more time.
It Started -
The only thing I did was take a pic of the wires under the front passenger seat. Obviously I moved the wires around to take the pic..
If the fuel pump relay as been hardwired/bypassed then I am guessing I have a loose wire connection.
I am still looking to find out for sure if a PO did some kind of re-wire work on the fuel delivery system.
Thanks again for any input...
Trav...
It Started -
Trav...
Long time no post but but here is where I made it to put pump back in tank pressed the killswitch reset button in the passenger side door colom new realy and fuse is good tried to start it nothing. I did my wire trick again and it spun so I put the realy back in it tried and nothing pump is still not spinning please help
