fuel system wiring problem!
Old Nov 24, 2010 | 08:11 PM
anthonya008's Avatar
4th Gear
Default fuel system wiring problem!
i had thought i needed a fuel pump but after playing around i found out the wiring or a sensor is bad in the fuel system. i jumped the emergency fuel shut off sensor and the car started i am trying to check any other sensors but i am not sure of the locations. does any one know where i could find a fuel system wire diagram i have a 1998 land rover discovery lse. The car will occasionally start but then dies out after 5 minutes and will not start again, i was thinking maybe a fuel temp senson or bad wires. so if anyone has any suggestions of help on where i could find the wire diagram please help!
Old Nov 24, 2010 | 08:13 PM
Replace your fuel pump relay.
RichardT
Apr 25, 2014 11:24 AM
stoneydeac88
Dec 9, 2012 10:29 PM
JumPeR04
Apr 7, 2011 09:52 PM
JMCPilot
Jan 1, 2007 06:19 PM
lilah
Mar 31, 2005 01:51 PM
