Sponsored by: CARiD
98 discovery fuel system problem
Old Dec 17, 2004 | 02:03 AM
lilah's Avatar
Default 98 discovery fuel system problem
My 98 discovery would not start a few days ago. My mechanic decided it had to be the fuel pump. The mechanic deemed it fixed. When I went to pick it up after replacement it wouldn't start. It has the same symptoms as before the pump was replaced. The starter turns over but it never picks up. Clearly it is not getting fuel. I am getting frustrated. Could this be a relay switch or sensor? Any ideas would be appreciated!!
Old Mar 30, 2005 | 06:37 PM
mikemeyer0's Avatar
Default RE: 98 discovery fuel system problem
Have someone turn the ke on and off a few seconds at a time while you get close to the fuel tank. If you hear the pump running the pump, relay and everything is fine. Check for spark. If no spark its poss. but i have to check it migh be a crank sensor. can someone verify if the 4.0l has a crank sensor, i think it does.
Old Mar 31, 2005 | 01:51 PM
anonimaus's Avatar
If you are getting spark and you verify the pump is kicking in, next item I would check is the fuel filter.
stoneydeac88
Dec 9, 2012 10:29 PM
JumPeR04
Apr 7, 2011 09:52 PM
anthonya008
Nov 24, 2010 08:13 PM
blast20
Sep 3, 2010 12:18 AM
