Fuse box and wiring
Old Dec 29, 2013 | 10:26 PM
LRadventure's Avatar
Default Fuse box and wiring
Howdy folks ! havent posted in a while, but the rover is slowly turning into a stately rig of awesomeness :P Unfortunately im having a few electrical issues im trying to figure out..Ok here are the symptoms. Seats are working intermittently. Radio, Mirror aren't working. Checked the fuses, all are good, busted out the test light, and im not getting power to Number 6 fuse and the number 3 fuse. pulled the fuse box, its clean inside and out, that's where im at now, im trying to find a schematic so i can backtrack all the way to the source, but having some trouble. Anyone with any hints tips or advice ? Ive downloaded the rave, it seems to be different than it used to be ? ok ive run on enough, ill be checking back frequently to see if ya'll have any idea's ..thanks in advance !!
Old Dec 30, 2013 | 12:28 AM
jimvw57's Avatar
The owners manual mentions checking fuses 13 and 12 (I think) as they feed the MFU and the ignition feed for the MFU (Multi Function Unit)
Old Dec 30, 2013 | 04:35 AM
ihscouts's Avatar
The ETM (Electrical Troubleshooting Manual) is in the large 590Mb file of the Rave. Circuit diagrams galore.
Tap this link and you'll be downloading the last and most current free version; http://www.landroverresource.com/rave.zip
Old Feb 15, 2015 | 01:17 PM
XCELLER8's Avatar
hey !
was there ever any resolution to this problem..?? I'm having the exact same issue no radio, cig lighter, mirror, no int wipers either......all fuses good.....BUT >>>> no power to the radio fuse, or the mirror fuse....
Old Mar 5, 2015 | 09:49 PM
XCELLER8's Avatar
well after some testing for power here and there....i found there was no power(12 v) at the fuse box for the 12 & 13 fuses......long story short.....ended up being the relay that powers the MFU ( or MF Me>>>>lol)....its located by the drivers footwell...closest one to the door.....replaced it withe one of the others( yellow) to quick test and eureka !
I used a relay "Intermotor # RY341)
iambhooper
Feb 20, 2014 07:17 PM
maxamilione
LR2
Jun 23, 2013 06:07 AM
Blakesrover
Feb 21, 2013 01:43 AM
ntavila
Jan 1, 2011 04:17 PM
dezlpower
23
May 4, 2009 07:56 AM
