wiring to fuse box for 5v
Old Jun 19, 2013 | 11:05 AM
maxamilione's Avatar
4wd High
Default wiring to fuse box for 5v
I'm adding a tablet to my 08 lr2 in the space where the cubby hole is,i have a tablet that fits perfectly. I would like it to be switched on and off with the car,part of it's usage is as a gps. The tablet requires 5v does anyone know what i can use to wire that into the fuse box by the passenger seat?
Old Jun 19, 2013 | 11:19 AM
Since the vehicle electrical system is 14.2 volts, you'll need some sort of adapter/regulator. They are pretty common.
Old Jun 19, 2013 | 02:41 PM
4wd High
well i know the cigarette lighter does 5v i was just wondering if i can wire like a cig liter extension into the fuse box
Old Jun 19, 2013 | 06:52 PM
If you say so, but then all the 12 volt plug in gadgets like GPS and camera chargers, and phone chargers would not work.
Old Jun 19, 2013 | 07:01 PM
Rovin4life's Avatar
You could basically wire an another cigarette lighter with the charger in the socket and placed out of the way. But you will never get it to shut off by itself cause the ipad is separate completely. plus you need to wire in an additional fuse to protect that circuit.
Old Jun 23, 2013 | 06:07 AM
DeathWind's Avatar
Search for a mini fuse circuit tap and wire it to an extra 12vdc outlet. Then use a car charger designed for the tablet. I did this for my GPS unit that I mounted in the cubby hole.The cigarette lighter IS 12 volts....it's the item you plug into it that reduces the voltage to correct level if needed....like most GPS and USB charged devices. You will have to take into account what Rovin4life said. You will have to manually turn off the tablet unless it's a daily driver, then tablet being in standby won't matter for tablet's battery. My garmin automatically turns off when it detects that it has lost voltage when I turn off the car, and comes on automatically when I turn on the car. I hid everything in the panel on the left side of the front passenger seat (panel by passengers left foot). I used string and wire to thread the garmins plug to the cubby hole. All wires are hidden and easy to remove if I sell/trade the vehicle.
LRadventure
Mar 5, 2015 09:49 PM
kriswd40
Jun 30, 2014 01:08 PM
Blakesrover
Feb 21, 2013 01:43 AM
Luv2Run
Aug 16, 2005 01:38 PM
ferrelltodd
Jul 24, 2005 01:22 AM
