Gears
Old Jan 14, 2014 | 01:31 PM
  #41
FantomRover's Avatar
Yeah Bputah was a dead end. The speedo and gps don't match, the speedo reads slower than the gps
Old Jan 14, 2014 | 03:08 PM
  #42
fishEH's Avatar
That would indicate stock gearing.
Buy a floor jack and some jack stands. Anybody who works on their Rover needs them.
Old Feb 26, 2015 | 05:45 PM
  #43
Jeff in Tucson's Avatar
Default Grenaded the Detroit Locker
When the rear Detroit Locker let go it also snapped both rear axles! It was set up this way as I had bought it from the original owner. The axles were stock. No front locker. Stock gearing. I had switched to Cooper STT 35" tires and that's all it took. I was planning to go with better and tougher anyway!
I drove out using front wheel drive only, from way back in Chiva Falls, Tucson, AZ.
The new set up is cool! The parts arrive from GBRutah.com later this week. ARB air lockers front and rear. 4.43 gearing with the reverse front. Front and rear diffs with thrust bolt mod (support under pinion/ring gear contact area to combat flexing while rock crawling). HD waisted axles for the rear.
I've never driven the D1 with stock gearing/tire ratios. It's had 32" since shortly after I bought it. Slightly larger than stock tires were on it that were trash and I had replaced them quickly.
I'll report back as to drive-ability on the highway and off road. I can't wait... AAAAAAH! It's going to be like Christmas in March.
RoverLand
Oct 18, 2006 09:55 PM
BMWLR
Sep 7, 2006 03:21 PM
extremetoy1
Jul 14, 2006 12:28 PM
Acer
Mar 29, 2005 07:27 PM
Acer
Feb 25, 2005 10:29 PM
