General question on electrical issues
Old Jul 10, 2013 | 07:11 PM
FLA Rover's Avatar
Default General question on electrical issues
This is my first Rover, all the Rovers I looked at had some sort of issue with electrical problems, especially sunroofs and windows being inop. seems like a common theme. Is that the case? neither sunroof will open nor will the rear door windows work. Cruise control is inop as well but that could be vaccum.
Old Jul 10, 2013 | 07:25 PM
See our tech area in the D1 part of the forum.
Rear windows can be the traces on circuit board in window ECU.
Sunroofs can be grounds, switch, etc. Usually problems with leaks as well.
Cruise can be vac, it has a separate vacuum pump, don't hook cruise lines to regular manifold vac. Also switch, ECU, etc.
The RAVE is the factory set of shop manuals, incluidng wiring diagrams and electrical troubleshooting guide. Free download in my signature.
Old Jul 10, 2013 | 08:00 PM
FLA Rover's Avatar
Thanks...
pauldavidanthony
Apr 28, 2012 04:57 PM
adigerol77
Jun 2, 2010 08:36 PM
Garrett
Feb 15, 2010 08:27 PM
tornado_735
Apr 27, 2009 10:45 PM
Sfef84
Feb 21, 2008 07:56 PM
