Generic ignition
Old Aug 27, 2016 | 01:05 PM
TOM R's Avatar
https://landroverforums.com/forum/di...ock-fix-35422/
Old Sep 6, 2016 | 09:28 AM
fishEH's Avatar
Knocked this out over the weekend. Only took a few pics. The linked write up is pretty much spot on so I didn't see it necessary.
I had a nice pile of metal bits/shavings fall out when I pulled out the tumbler.
Also took two attempts at grinding the individual tumblers because I didn't grind down enough the first time.
Only 1 key needed now!!!
Old Sep 6, 2016 | 11:41 AM
Toran's Avatar
Greetings Mr Fish!
Congrats on the needing only one key now, and thanks for the two images.
What kind of tool did you use for grinding? I am hoping my dremel will do the job.
You’re a bit more handy and was wondering how much time to dedicate to this task?
Thanks
Old Sep 6, 2016 | 04:55 PM
fishEH's Avatar
I would budget 3hrs. I used a Dremel with cut wheel to cut a slot for a flat tipped screwdriver in each one of the ignitio screws. Then I used a right angle screwdriver to break the screws loose and got them by hand the rest of the way.
I used a bench grinder on the tumblers but I'm sure a Dremel would work, although having the wire wheel to smooth things out afterwards was nice.
There's a bunch of wires around the ignition. When reinstalling they go UNDER the ignition. The plastic shroud won't fit if you put them over the ignition. Ask me how I know.
Originally Posted by Toran
Greetings Mr Fish!
Thanks
Old Sep 6, 2016 | 06:30 PM
Toran's Avatar
Thanks!
I'm on it right now, when I am done I hope to be a one key user too!
I also discovered this truck has an ignition switch light...eheh
Old Sep 6, 2016 | 08:32 PM
fishEH's Avatar
Thanks!
Yep, there's a light in there too.
Old Sep 7, 2016 | 11:29 AM
Toran's Avatar
Thanks Mr. Fish!
I am now rollin with one key too!
p.s.
That ignition switch light was so dim I replaced it with another 2721 bulb but its still dim
Jwhitfie
Dec 11, 2015 11:35 PM
Childeric
Apr 10, 2014 03:26 PM
will rocket
Off Topic
Sep 12, 2013 06:23 AM
1998DiscoverySE
Jun 27, 2012 01:56 PM
hayes156
May 13, 2008 12:35 AM
