good tire pressure
The correct pressure depends on the tire, it's load rating, and the axle loading you have.
You can't say x pressure for y tire.
There are two ways to get the correct tire pressure for your setup.
1. Chalk the tire and roll the vehicle to see the tread pattern it leaves and adjust the pressure based on the pattern it leaves.
2. Call the tire mfg and give them the tire size, model, load rating and vehicle weight per tire and they can tell you the suggested pressure.
For instance, I called Cooper and these were the inflation pressures for my load range D 7.50Rx16 Discoverer STT's
Loading
per
wheel
in
pounds PSI
2390 60
2190 55
2040 50
1930 45
1770 40
1620 35
Loading
per
wheel
in
pounds PSI
2390 60
2190 55
2040 50
1930 45
1770 40
1620 35
