Head gasket at 237,000
Old Apr 23, 2025 | 07:25 AM
whiskeynipple0088's Avatar
thanks Walt!
Old Dec 30, 2025 | 08:42 AM
Ozark4WD's Avatar
Originally Posted by WaltNYC
All done. Replaced the motor mounts which were way overdue. Runs smooth and has a tiny bit more power. When I put my foot on the floor on the highway, it kicks down nicely.
I fortunately replaced all the coolant lines which avoided any nagging leaks upon rebuild.
It is a big/long job, but one that is quite satisfying. I'll get another 150k out of her.
I did not find a ground strap anywhere (aside from the starter). Is there an engine ground strap on a 1997 D1?
Next job is suspension bushings.
Walt, did you had to do any machining on the heads or were these still within the spec?
Also, great write up! Thank you.
Old Dec 30, 2025 | 09:29 AM
WaltNYC's Avatar
I didn't check them, but at 237k I thought I had gotten my money's worth and had them done by default. A valve job was also performed. Yeah, I may have spent more than I needed, but I don't have the time, space, or infrastructure to do this type of job often. I wanted to remove all doubt.
Old Dec 30, 2025 | 10:06 AM
Ozark4WD's Avatar
Got you. Makes sense. I live in the very rural area, so finding good machine shop, lol, finding machine shop at all here is a challenge. I hope when it comes to this, my heads will be within the spec...but I guess we will see...
Old Jan 7, 2026 | 01:57 PM
WaltNYC's Avatar
gonna add one more thing..
I clean and chase the head bolt threads. My intent is to make them 'like new' in terms of lacking any debris, dirt, oil, or other fluids. Then brake clean followed by compressed air.
Old Jan 7, 2026 | 04:18 PM
Mark G's Avatar
Good idea. Helps achieve the 'correct' torque setting too
TheVolunteers
Dec 19, 2017 02:51 PM
earlyrover
Apr 10, 2017 09:25 AM
Savannah Buzz
Aug 8, 2013 02:47 PM
Disbet
Jun 11, 2009 08:58 AM
Steve O
Aug 25, 2006 04:26 PM
