Head gasket replacement help/advice
Thanks, I think I've had it off already so I shouldn't have any trouble.
If they will come out I'll do that.
BTW does anyone know if I can drop the oil pan without removing any drivetrain parts? I looked last night and it looked kind of tight. I'd like to clean out the bottom of the pan because this engine looked like the previous owner never changed the oil.
I've read that they can mushroom a bit at the bottom and won't come out unless you remove the cam and pull them out the bottom. I have no idea if mine are like that though.
They can and do become mushroomed and then they have to be dropped out through the cam bore. If they're mushroomed without question just replace them, the cam, bearings and the pushrods. Go aftermarket on the cam and SB Buick on the lifters. You'll get a little more lift out of your valves and the top end will remain in action long after your in a pine box.....
Heres another great headgasket thread.
https://landroverforums.com/forum/di...ree-way-59520/
