Head Gasket suspected but no Overheating
Old Dec 7, 2011 | 07:12 PM
Free download of RAVE tech and owner's manual below.
Old Dec 7, 2011 | 08:46 PM
White smoke in the cold weather is normal, water coming out of the tailpipe is also normal.
95% of all O2 codes on a Discovery are because it needs a tune up, that means new plugs and wires.
Remember that you must use premium gas in these trucks.
Read the entire owners manual to understand your truck and how it all works, there is a cubby hole under the drivers seat, check there if it is not in the glove box, under the passenger seat is the CD changer.
Old Dec 12, 2011 | 10:04 AM
steaktaco's Avatar
5th Gear
OK. So here are the codes--all related to 02 sensor and misfire: 1193,0130,0158,0138,0151,0300,0304,1316,0430. So I'll check wires and plugs, especially cyl. 4. I already saw that there are new looking Bosch platinums in there but the wires look a lot older. I'm no longer worried about head gasket. White smoke goes away and it isn't anywhere near overheating.
Thanks
Old Dec 12, 2011 | 11:19 AM
If you think wires look old, they need swap out. You may even be able to see electric discharge at night in the pitch black along the wires. Overheat should be defined in your mind as anything above 9:00 on the gauge, it has a very broad range. Check your fluids weekly. Consider the handy Ultra Gauge, about $70, digital multi function gauge and code reader.
Attached Thumbnails Head Gasket suspected but no Overheating-images%5B11%5D.jpg
somebodeh
Freelander
Feb 23, 2014 07:02 AM
Roflcopter
Mar 27, 2013 05:07 PM
flanker6
Jan 15, 2013 01:15 AM
Schwanee
Nov 15, 2012 02:44 PM
disco2008
Apr 17, 2008 08:54 PM
