head light issues d1
Old Sep 24, 2011 | 08:40 PM
wesley64's Avatar
Default head light issues d1
hi ,i have a 1997 d1.my problem is that when i turn the headlights on the dash tail lights and side markers will not come on but the low beam will.when i switch to high beam the dash tail lights and side markers and hi beam come on.do you think this could be a switch issue?
brett
Old Sep 24, 2011 | 09:01 PM
Yes, this sounds like a bad switch to me.
Old Sep 24, 2011 | 09:04 PM
Perhaps. On my 97, the first click brings on the small secondary "city lights" bulb in the head light housing, on the second click the main head light bulb comes on. But on mine, that first click also brings on the dash lights and the tail lights and the front side marker lights. You may want to download the RAVE tech manuals set, and jump into the Electrical Troubleshooting Manual (separate from workshop manual). The wiring diagrams are pretty easy, like a road map.
Old Sep 24, 2011 | 09:12 PM
fishEH's Avatar
It's probably the switch, aka the headlight stalk. You should be able to source a good used one from Will Tillery, PT Schram, or Paul Grant. Replacing the switch is super easy.
Old Sep 25, 2011 | 02:35 AM
wesley64's Avatar
thanks guys.i will try a switch
brett
Old Sep 25, 2011 | 03:09 PM
Danny Lee 97 Disco's Avatar
I agree, my stalk switch went bad, when I switched to headlights, the dash and tail lights would go off. I could force the switch with pliers, it would work that time but problem would repeat every time. I got a good used one from either Will or Paul, don't remember which one for like $40 or so shipped. Problem fixed.
Flyin2jz
Engine & Internal
19
May 4, 2012 08:07 PM
Kalel
Jan 28, 2012 10:22 PM
marlymarl
May 28, 2011 10:34 PM
rhino_e28
Aug 31, 2010 04:06 PM
