heat problem in the rover.
#21
#26
on
Often times those wheel bearing will weld themselves in place when they fail and that can be a nasty job to deal with.
If you are having problems finding a seal, try Rovers North. They stock all the correct items like that.
If your serp belt has a chunk out of it, I wouldn't keep driving it like that. If the water pump bearing is bad, you should definitely take care of that as well.
umoms
04-03-2008 06:22 PM
