Heater blower and windows stopped working 98 discovery
When you inspected the fuses was it visually or with a multimeter / continuity test? Fuses 11 and 12 (under hood) in bank A control window lift ecu and blower motor. Since you say they went out at the same time I would start by checking that fuse and its wiring connections. just a guess...
We visually checked the fuses. I took it to a mechanic and they looked at it for a couple of hours. Not sure if they did that. I live in yakima, Washington and there are only two mechanics here that will touch land rovers. I will check them today to be sure. I had no issues with anything prior. I was driving and all of a sudden the blower stopped. It was cold and the windows fogged up that's when I noticed that the windows were not working either. Everything else is fine.
You've come to the right place for help.
Have you tried new fuses? Just in case your visual inspection didn't catch a minor defect?
