Heater Hose Piped To Manifold: Same size both ends?
It's #47 in the coolant diagram from Rovers North. Looks like it's a different size on both ends. Is it? If not, I'd like to pick up the part at a local parts shop today and get this baby fixed! I appreciate your knowledge. :-)
1997 D1 V8
-Danielle
http://landroverparts.roversnorth.com/ProductDesc.aspx?code=PEH101530
1997 D1 V8
-Danielle
The diameters are different on both ends. One end is about 19mm, the other 22mm.
Here is a better pic and part number(PEH101530 )....
Hose - Heater Manifold To Pipe (Part # PEH101530) - Land Rover heat\defroster\ac from Atlantic British
That looks fantastic! Thanks antichrist! I'll be changing that out this evening. In the meantime, I ended up putting on a 3/4 and stretching the one end. Obviously this isn't a good solution, but it did get it home yesterday without a tow.
On another note, anyone know why the top radiator hose might look squished after I turn the truck off? I thought it was a cap thing, but I have a new one on and it still does it.
Thank you guys for your help! I truly appreciate all on this forum. :-)
br0keit
10-01-2013 06:54 AM
