Heater Hose Piped To Manifold: Same size both ends?
Old Oct 6, 2013 | 03:26 PM
dnbrown9's Avatar
Default Heater Hose Piped To Manifold: Same size both ends?
It's #47 in the coolant diagram from Rovers North. Looks like it's a different size on both ends. Is it? If not, I'd like to pick up the part at a local parts shop today and get this baby fixed! I appreciate your knowledge. :-)
1997 D1 V8
-Danielle
http://landroverparts.roversnorth.com/ProductDesc.aspx?code=PEH101530
Old Oct 6, 2013 | 06:38 PM
OverRover's Avatar
The diameters are different on both ends. One end is about 19mm, the other 22mm.
Here is a better pic and part number(PEH101530 )....
Hose - Heater Manifold To Pipe (Part # PEH101530) - Land Rover heat\defroster\ac from Atlantic British
Old Oct 7, 2013 | 03:39 AM
antichrist's Avatar
https://landroverforums.com/forum/ge...56/#post335334
Old Oct 7, 2013 | 08:03 AM
binvanna's Avatar
You wonder why Rover engineers don't solve problems that way. Instead they think, "let's do a custom molded hose thingy." They must have had a boat load of the larger diameter nipples or something.
Old Oct 7, 2013 | 08:53 AM
antichrist's Avatar
No, I quit many years ago wondering why engineers built cars the way the did...it gave me headaches.
Old Oct 7, 2013 | 11:05 AM
dnbrown9's Avatar
That looks fantastic! Thanks antichrist! I'll be changing that out this evening. In the meantime, I ended up putting on a 3/4 and stretching the one end. Obviously this isn't a good solution, but it did get it home yesterday without a tow.
On another note, anyone know why the top radiator hose might look squished after I turn the truck off? I thought it was a cap thing, but I have a new one on and it still does it.
Thank you guys for your help! I truly appreciate all on this forum. :-)
Old Oct 7, 2013 | 12:41 PM
antichrist's Avatar
If you have air in the system it can do that.
br0keit
Oct 1, 2013 06:54 AM
binvanna
ROAMING WITH FRIENDS
Jan 22, 2013 01:56 PM
amaxson
Jun 23, 2011 10:48 AM
llPANCHOll
Apr 22, 2009 02:53 PM
ronev
Jun 20, 2006 01:43 AM
