Heavier Truck needs more power....?
Old Jun 14, 2012 | 01:42 PM
  #31
wheelgarage's Avatar
Okay...I finally found a shop that can rebuild and install the gears for $225 each. Some other shops wanted as much as $350 each!!! The service price is only if I bring in the 3rd member(s)...
I am reviewing the manual on how to rebuild one myself. At first review, it looks like I will need additional tools...which is way less cost than servicing one of them. But, it is straight forward. The measurement tools are the biggest items.....to make sure it is all done to spec...
My wallet needs to recoup from the service cost of my commuter. I had both CV's and an engine mount go out at the same time?!?!?!?!.... Looks like this task will get pushed off until the end of summer....oh well...back the affordable projects for now.
Old Jun 14, 2012 | 02:05 PM
  #32
Jake1996D1's Avatar
Why not have Justins diff guy build them? He charges 225 I think. With all new bearings.
Fwiw I built mine. Only takes a in/lb dial torque wrench and a dial indicator.
Old Jun 15, 2012 | 09:42 AM
  #33
ihscouts's Avatar
....and feeler gauges.
Old Jun 15, 2012 | 12:10 PM
  #34
What....are you sure, bearing and races included in the $225! Shipping would probably cost $100 back and forth for two plastic containers.
I only asked Justin about the install kit....
Seriously thou, I know I can build it myself. I just need to buy the extra tools....which I need anyway.
Old Jun 15, 2012 | 12:39 PM
  #35
Jake1996D1's Avatar
Feeler gauges for what? I used a mic to measure and record shim sizes. You could use one of those pinion depth tools but generally speaking if you use the same shims that came out of the diff it will get you pretty close and then you can just adjust the depth based on the pattern
Old Jun 15, 2012 | 12:41 PM
  #36
Jake1996D1's Avatar
Sorry the site says $298 Lucky8 Llc. - Take the road less traveled... but I swear he quoted me $225 when I asked him about it. You should have told me you wanted to do this I could have sold you two diffs for cheap and then just gave them to Justin to have his guy build them and ship them out to you.
Old Jun 16, 2012 | 06:31 PM
  #37
Dude, I didn't have this covered when I made my build list. I completely over looked this. Oh well it wasn't meant to be.
I'm going to just buy the Ashcroft gears and rebuild kit next week then....can't wait till the end of summer. I get the lockers done next year. Don't need them for the trips this year anyway.
Just can't tell my wife I spending money on the cars again, and just after my commuter car expense...hehe...I truly believe auto parts are more important than purses...
Old Jun 18, 2012 | 08:18 AM
  #38
Jake1996D1's Avatar
Do it all at the same time if you can - setting up a gear set multiple times is usually a recipe for noisey gears cause you cant really see contact patterns on used gear sets
Old Jun 18, 2012 | 12:16 PM
  #39
Good point....I willl wait for the lockers than....
Okay...out to go buy a purse..
Wilson7287
Aug 16, 2015 10:44 AM
Bryan H
Feb 12, 2009 10:59 PM
pjpruden
May 18, 2007 07:38 AM
pfkb72
Oct 1, 2005 10:10 PM
drfeldman
Apr 7, 2005 03:18 PM
