Hello from russia, i have a qwestion!
workshop manual is first......the real manual is second...its called the rave good luck
http://www.landroverresource.com/doc...hop_Manual.pdf
http://www.landroverresource.com/rave.zip
Land Rover - Land Rover Repair Manual: 3.5, 3.9, 4.0, 4.2 and 4.6 V8 - Bentley Publishers - Repair Manuals and Automotive Books
Land Rover, Range Rover, Europe, Microcat, Defender, Defender 300TDI, Discovery Series II, Freelander, Integrated Diagnostic System (IDS 116), LR 90 / 110, Santana, Serie I, Classic, EPC, V8-3.5L, Werkstattliteratur, Reparaturhandbuch, Servicehandbuc
If no spark, maybe part of the ignition system (ingnition amplifier module) used on some early models.
We need more information, what does the engine do?
Does it crank over fine with the starter but just not start?
Have you verified that you have fuel pressure at the engine?
Have you verified that you have spark?
On the right side of the engine is a schrader valve (looks like a tire valve) with a cover on it, remove that cover and using a fuel pressure tester check for fuel pressure, attach the gauge, crank the engine over while a friend watches the gauge.
You need to be around 35psi. (2.4bar)
You can also cheat and use a dial tire pressure gauge.
Second remove one spark plug and lead wire, reattach the lead wire to the spark plug and lay it on the exhaust manifold (extractor) and have your friend try and start the engine, does the spark plug spark?
Please report back with what you find out.
Yes, only first day of problems, next day no. Accu charged.
No, but fuel pump is new.
Yes.
My engine cannot have this valve.
Yes, first day.
Before this trouble i leave key in car on pos 3 withowt starting ingine about 10 minits - this not be cause?
Yes.
Yes, first day.
