Help..?
Old Mar 28, 2016 | 08:20 AM
  #21
CATTIVA73's Avatar
Originally Posted by MrValingo
Unplug the one with the purple wires. Once it's unplugged, if the ring around the ignition cylinder doesn't light up anymore, then that's not the one for the ignition lock. Plug it back in and try the other plug
WHICH OTHER PLUGGGG !!! ??? lol
Old Mar 28, 2016 | 09:01 AM
  #22
Coachgeo's Avatar
In case your actually serious....... there is only two in the area your working.
Old Mar 28, 2016 | 09:51 PM
  #23
Island_Dave's Avatar
This is painful
Old Mar 29, 2016 | 06:49 AM
  #24
CATTIVA73's Avatar
Default IT is painfull!
There are Actually Three plugs....the one next key hole with two purple wires, the big white one (see pics) and one located on the very back of key barrell...at this point I'd like to hear from someone who has done it n can write clearly WHICH ONE!
Thanks
Old Mar 30, 2016 | 07:14 AM
  #25
CATTIVA73's Avatar
Thanks
....Anyone???
Old Mar 30, 2016 | 06:34 PM
  #26
ihscouts's Avatar
There is a set of wires that go to a small plug on the backside of the key barrel assembly. They're white and black, that is the key barrel lock solenoid. Remove the small two wire connector from that solenoid. It's easier to see from the left side of the steering column or just trace those two wires which come out of the multi-wire white plug.
Old Apr 5, 2016 | 02:12 PM
  #27
CATTIVA73's Avatar
you're awesome. thanks
Old Apr 5, 2016 | 05:08 PM
  #28
ihscouts's Avatar
Don't tell anybody, trying to keep a low profile....... Your welcome. I tied the two wires together - the white and black to keep the circuit live. If your having any issue after removing the plug just copy what I did. Like Tom, I removed mine a long, long time ago, hard to remember what and why but I did keep my old assembly just incase cuz you never know. I ended up using a manual's assembly and have only the ignition switch and key light functional and nothing else. As a matter of record you could start my truck with a screw driver and I can remove the key while I'm tooling down the road and engines still lit. I did that for a couple of reasons, once you have your truck dragged onto a flat bed you'll know why it's better to have options.......
Old Apr 5, 2016 | 07:09 PM
  #29
Shiftonthefly1's Avatar
Lol. Best thread ever
Old Apr 5, 2016 | 07:29 PM
  #30
ihscouts's Avatar
Infotainment.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
