Help!! Gas in 1995 discos oil.
Old Jan 27, 2021 | 06:08 PM
Tommyblack97's Avatar
Default Help!! Gas in 1995 discos oil.
Help!! Gas in 1995 discos oil. I just bought this disco and was told nothing was wrong with it but the distributor. Went to flush the fluids and I pulled the oil filter first. It was full of blueish/greenish gue. So I panicked. Pulled the plug out of oil pan and thin liquid poured out smells strongly of gas. No brownish tint at all. All other forums I’ve seen are saying maybe the piston rings? What do y’all think?
Old Jan 27, 2021 | 06:20 PM
Best4x4's Avatar
You have an injector either sticking open or firing at the incorrect time (could be plugged into the wrong connector which can happen easy with the middle 2 cylinders) causing fuel to go past the piston rings and into the crankcase. Change the oil with some cheap stuff, ASAP and if I were you I'd just but some new Bosch 4 Hole Injectors for like 50.00 for a set of 8 on eBay.
redrover75
Oct 1, 2014 11:50 AM
SeasideRHT
Nov 3, 2011 09:49 AM
deer killin disco
Jun 9, 2011 02:31 PM
EVN137
Jul 9, 2007 08:16 PM
4x4freak
Apr 10, 2007 12:55 PM
