Help me diagnose this leak?
96D1-100K. It's oil, it's new and it appears to be at the connection of the hose and "oil expansion tank". ALSO I think unrelated, Oil is also now leaking at the gasket of the oil pan thanks to my local rover mechanic. We will try and tighten today. Local Rover mechanic just did timing/cover/oil change (amsoil). I'm really not sure what I'm looking at here as you might be able to tell.
Here's a link to what the oil separator should look like Oil Separator - Valve Cover | Land Rover Engine Parts at RoverParts.com
The list is not in the RAVE, it is in the tech sticky section of the Discovery 1 forum part of this forum, along with lots of other good stuff to know, that has been filtered of the obscure opinions frequently thrown out by myself and others.
Pull separator out carefully with needle nose pliers. Clean with solvent, re-install. If broken, replace. If clogged, oil can be forced out seals. This is in the top of the valve cover. In the olden days, this is what would have been called a crankcase breather. Became PCV valve in later cars, but this has no valve, just a baffled corkscrew of plastic.
