help needed
hi all help if you can , just noticed that my rear shock absorber drivers side has broken off at the axel , can this mount be welded back or do i need a new axel with complete mount
many thanks guys .
many thanks guys .
I would add that if you take it to a fab shop, have them build a new mount, it souldn't be a lot more expensive than having them weld your old.
Old mounts tend to break again in a short period right beside the weld.
It looks like you could use new shocks as well.
If one side broke off, you may as well have them do both sides at one time. If you only do one and the other side is weakened from age and condition, it will go shortly.
Cheaper to do both at one time than to have them do one at a time twice.
Does it sag overall? maybe time for new springs as well. My 97 was saggfing like they all do eventually. New springs and shocks made a hell of a difference in stance and ride. A two inch lift raised it over 3.5 inches from sagging to new.
mandythelandy
Engine & Internal
Apr 9, 2008 01:15 PM
redmel
Nov 14, 2005 09:03 AM
