help needed
Old Oct 22, 2010 | 09:37 AM
mashy's Avatar
6th Gear
Unhappy help needed
hi all help if you can , just noticed that my rear shock absorber drivers side has broken off at the axel , can this mount be welded back or do i need a new axel with complete mount many thanks guys .Name:  mn030.jpg
Old Oct 27, 2010 | 10:31 AM
okdiscoguy's Avatar
Take it to a fab shop and have it welded back on.
Old Oct 27, 2010 | 11:59 AM
ColoDisco's Avatar
X2 should be a easy fix
Old Oct 27, 2010 | 12:32 PM
tornado_735's Avatar
Yep, that repair is easy peasy lemon squeezy. You shouldn't have any problem finding a shop to do it. Just make sure they do it right so you don't fail MOT.
Old Oct 27, 2010 | 01:05 PM
Jull's Avatar
I would add that if you take it to a fab shop, have them build a new mount, it souldn't be a lot more expensive than having them weld your old.
Old mounts tend to break again in a short period right beside the weld.
Old Oct 27, 2010 | 01:18 PM
NiteTrain's Avatar
X2 on having a them make you a NEW mount..your old one looks like a hunk of rust..I wouldn't try welding it back to the axle
Old Oct 27, 2010 | 09:43 PM
Danny Lee 97 Disco's Avatar
It looks like you could use new shocks as well.
If one side broke off, you may as well have them do both sides at one time. If you only do one and the other side is weakened from age and condition, it will go shortly.
Cheaper to do both at one time than to have them do one at a time twice.
Does it sag overall? maybe time for new springs as well. My 97 was saggfing like they all do eventually. New springs and shocks made a hell of a difference in stance and ride. A two inch lift raised it over 3.5 inches from sagging to new.
Old Oct 28, 2010 | 09:27 AM
mashy's Avatar
6th Gear
thanks guys . got it fixed new mount new shock and new stabiliser bar think thats what its called all in £110 was expecting it to be alot more .
Old Oct 28, 2010 | 11:56 AM
ColoDisco's Avatar
Post some pics.
Old Oct 28, 2010 | 12:43 PM
Awesome!
mandythelandy
Engine & Internal
Apr 9, 2008 01:15 PM
DiscoPete
Sep 29, 2006 03:22 PM
masher
Dec 31, 2005 09:56 AM
redmel
Nov 14, 2005 09:03 AM
asmcmillin
Apr 4, 2005 02:04 PM
