Help With OBDII Data
Old Feb 2, 2013 | 05:02 PM
LeakyDisco's Avatar
Default Help With OBDII Data
Ran the scanner (Torque for Android) on my 97 today. Below is what I got back from the test results, but I am not entirely sure what it means. The sensor fail was in bank 1.
Any help is appreciated.
https://dl.dropbox.com/u/7793875/screenshot.jpg
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$03 CID:$01
- Low sensor Voltage for switch time calculation
Max: 50
Test result value: 300
FAIL
TID:$04 CID:$01
- High sensor Voltage for switch time calculation
Max: 250 Min: 50
Test result value: 200
PASS
TID:$05 CID:$01
- Rich to Lean sensor switch time(calculated)
Min: 65,086
Test result value: 65,287
PASS
End of report.
Old Feb 2, 2013 | 08:48 PM
Here is the book on the 97's ECU, and how all the codes are calculated, and their voltage values, etc. What is in the factory book does not match the values from your Android app. Maybe you's is "generic". Did you get any other codes that start with "P"?
File Type: pdf
Old Feb 2, 2013 | 09:05 PM
LeakyDisco's Avatar
Thanks.
No codes from the ECU at all. Maybe I don't have the app calibrated or setup for the vehicle correctly.
Old Feb 2, 2013 | 09:13 PM
Rover also may use some codes differently from other vehicles.
BluePointDisco
Jan 29, 2017 03:16 PM
caymandrew
Mar 14, 2013 02:03 PM
Robover01
Nov 24, 2009 11:09 AM
endneu913
Oct 24, 2007 01:32 AM
Oscar G
Aug 20, 2007 05:18 PM
