High Idle!
Old Aug 17, 2012 | 06:28 PM
  #21
Danny Lee 97 Disco's Avatar
I agree there are many things that can casue the high idle, that is why I suggested he check with a local dealer for a reset.
I would just like to be confident in what I read on here. And I do see a few contraditions. That is all I was pointing out.
All of us hate to throw money at a problem or have misleading info.
If diconnecting the TPS is a no no then I would like to know that and I do see others advising to do it. We all need good constructive advice and to learn from each other.
I do remember Spencer going thru lots of problems with his. I just wish he would supply good details, that is all.
Old Jan 26, 2013 | 01:59 PM
  #22
bcbp's Avatar
Well I finally solved my sporadically high idle issue with an ecu reset. I took it to ASC Automotive in Jersey. With the truck idling somewhere around 2100-2200k the tech plugged in the scanner and with the push of a button the idle immediately dropped. Took about 10 minutes and only $50, those guys are great.
What I tried: Replace the TPS, IACV, Battery, alternator, and checked all the vacuum lines.
Old Jan 31, 2013 | 01:59 PM
  #23
gprtech's Avatar
Did you see what kind of scanner he used?
Old Jan 31, 2013 | 07:05 PM
  #24
one popular group - Blackbox Solutions Ltd. -- Products Page
Old Feb 1, 2013 | 03:10 AM
  #25
bcbp's Avatar
Auto logic.
Old Mar 9, 2014 | 09:43 AM
  #26
Kobus van Eeden's Avatar
Hallo everybody, I have a Disco 1 '96 V8i, have problem with the idling, at start up idle skyrocket and slowly comes down to about 600-700 rpm, replaced the stepper motor, having a howling sound coming threw the air cleaner at idle speed, can anyone assist. Thank you in advance.
Old Mar 9, 2014 | 07:50 PM
  #27
TOM R's Avatar
If you change the stepper the ecm needs reset, you sure the howling sound isn't the coolant fan?
And asc is an awesome rover shop great guys, they reset my ecm
Old Mar 10, 2014 | 02:24 PM
  #28
Default reply on high idle
Hallo TomR, can you explain to me how to reset the ecm, and yes I am sure the sound comes from the aircleaner when I open the aircleaner the sound is even must louder, it happened right after I cleaned the base idle skrew, I have strip the plenim and clean it but the noise is still there. Thank you in advance
Old Mar 10, 2014 | 07:26 PM
  #29
TOM R's Avatar
Ecm reset is dealer or rover shop
You should not have tampered with base idle screw
Is the big print missing where MAF sensor goes on air cleaner?
Old Mar 11, 2014 | 05:46 AM
  #30
Default High idle
Part off the big print is still there but is unreadable, somewhere in this forum is a discussion on the stepper motor faults whereby they discussed the cleaning process of the base idle.
