high idle
Old Jul 29, 2013 | 07:46 AM
  #41
I was fortunate to swap an ecm and IACV from same truck and it worked. Many say you have to swap green alarm box at same time. Hopefully yours will be solved by having a tech speak to it with a computer.
Old Aug 4, 2013 | 02:53 PM
  #42
TOM R's Avatar
I will probly need to do that, so is it just 96-99 disco 1 with 4.0 or is there some other that will work,
in my ongoing search for a fix I had read a post found in a Google search referencing Being able to use a newer ecm,
but newer would mean Bosch right?
Old Aug 4, 2013 | 04:23 PM
  #43
I thought Lucas made the GEMS as well... Bosch certainly makes the Motronic used in the D2s.
Old Aug 4, 2013 | 04:29 PM
  #44
jafir's Avatar
I think I read that it was a cooperative creation of Lucas and SAGEM.
Old Aug 4, 2013 | 08:09 PM
  #45
TOM R's Avatar
OK so what does this mean for me? Going to VA end of week and hope to hit the big u pull while there so need to know just what I can use the ecm from
Old Aug 4, 2013 | 08:11 PM
  #46
jafir's Avatar
Stick with advanced evap loss type computers like what you've got, mid 1997-1999. Grab the green alarm box if it is there, just in case.
Old Aug 12, 2013 | 08:58 AM
  #47
TOM R's Avatar
Is there some chance a 99 d2 4.0 Bosch ecm will work I can get this??? The ecm says on it Bosch and D1 real big, located pass kick pannel
Old Aug 12, 2013 | 10:27 AM
  #48
Here is a short booklet on the various fuel injection models and the sensors used with them, sensors from one model may not work with a different ECU.
File Type: pdf
Old Aug 12, 2013 | 06:10 PM
  #49
TOM R's Avatar
Thanks I drove 2 hours to another u pull and found 98 disco 1 , got ecm, green box, vss, maf,intake tube, what looked like a new Plenum with new sensors and cruise diaphragm, CD changer for the one I drowned,set uf Bosch plug wires,set of ignition coils, some misc screws I needed
Had fuel send or but it was rusted like mine so passed, forgot crank sensor
If I do not have enough to fix the problem think I will give up
Old Aug 20, 2013 | 01:20 PM
  #50
TOM R's Avatar
Good day today, no more high idle swapped out ecm and Plenum with matching sensors attached (tps,iacv) now around 760 rpm +/- , tps 12.2
Hope it lasts, got the green box but did not need it and remote still works
I did run the engine after Plenum swap before ecm swap no change,instant fix with ecm though
