high idle troubleshooting
Old Jan 30, 2013 | 04:59 AM
  #21
gprtech's Avatar
I would have cleaned the MAF at the same time as the IAC.
Old Jan 30, 2013 | 07:19 AM
  #22
Sarge103's Avatar
Originally Posted by gprtech
Of course I see no reason to have the VSS provide the ECU with information to limit the top speed of the truck either, and LR did that.
Well my VSS is going I have the sputtering problem and when it happens my speedo is reading 70mph and my scan gauge is reading 188mph, I am going to try the rebuild process as soon as i get some down time from work.
Old Jan 30, 2013 | 07:20 AM
  #23
Sarge103's Avatar
I will clean the MAF the iacv is clean since its brand new then i will disconnect the battery for an hour or 2.
Old Jan 30, 2013 | 07:28 AM
  #24
Sarge103's Avatar
well after doing some reading on the forums maybe it isnt a good idea to clean the MAF it looks like it could do more harm than good.
Old Jan 30, 2013 | 07:44 AM
  #25
Not true. But you are correct to be concerned. The MAF heats a small part inside to 350F above ambient. If you spray cold made-for-MAF spray on that hot part, the heat stress certainly can fracture it. The MAF is also powered up with the other sensors when you go to position 2 on the ignition. So DIY Dude turns on the key to check something in the garage, turns off the key, and shoots the sherbert to it. That sensor has not cooled off. Bad things happen to a sensor that sells for $1400. After cleaning expect erratic starting the first few times.
OK to clean it with made for MAF spray, when sensor has not been powered up overnight. I have cleaned mine a few times, plus ones in other vehicles.
Don't use something you have sitting around, like carb cleaner, brake parts cleaner, electronic cleaner.
You can drive truck without VSS connected.
Here's a pix of an earlier style of MAF sensor, one of the tiny spots is heated, then the difference in resistance is measured as air flows over the two items, and the mass of the air flow is calculated. BTW, those who go wading with their Rover, and get a slug of cold mountain stream water down the MAF risk the same problem.
I have a spare MAF from the boneyard, which at $29 was cheap insurance.
And be sure that you depress the hood alarm switch before re-connect of battery. Best if truck left unlocked during the whole process.
Old Jan 31, 2013 | 12:37 PM
  #26
gprtech's Avatar
One other thing - the MAF measures airflow by the difference in temperature it measures internally, but it compares that temperature to that measured by the intake air temperature. If that's not measuring correctly, it could cause similar problems.
At the very least, check & clean. I haven't used a scanner on my truck yet, so I don't know if it would give you the reading from the sensor, although I would think it would.
Old Jan 31, 2013 | 01:49 PM
  #27
Sarge103's Avatar
You mean IAT reading ? because i do have that option.
Old Jan 31, 2013 | 02:55 PM
  #28
gprtech's Avatar
Yeah, check that against the actual ambient temperature.
Old Jan 31, 2013 | 07:02 PM
  #29
On a D1 the IAT is a separate sensor plugged in the side of the air filter box. On a D2 it is part of the MAF assembly. Both the IAT and the ECT (engine coolant temperature) sensors should show about ambient at start up.
Old Feb 1, 2013 | 05:23 AM
  #30
Sarge103's Avatar
checked it this AM before heading to work both IAT and coolant temp matched ambient outside temp on startup.
wick_60010
Nov 22, 2017 04:25 AM
omarica7
Mar 11, 2014 08:12 AM
gmal
Apr 26, 2008 02:10 PM
fireball168
Nov 11, 2007 03:12 PM
