high pitched whine
Old Dec 3, 2018 | 07:14 PM
NVRover's Avatar
Default high pitched whine
Question for the group... My 98 disco has picked up a whine in the engine compartment on driver’s side. It changes pitch with acceleration, or under load. Once the engine is warm it doesn’t make noise at idle. Could this be the beginning of either the water pump or power steering pump going? Both currently work well.
Thoughts?
Update:
It has progressed from a whine to a very healthy scream. I did a lube test on each of the pulleys, a squirt of lithium grease on each at the bearings and listening for the pitch change. Outcome...my three month old alternator appears to have a bad bearing. I guess I will be pulling it again.
cobbcj7
Dec 29, 2023 01:43 PM
TaylorCadence
Jul 2, 2018 05:04 PM
expedio2005
Feb 2, 2013 02:58 PM
RegT
Apr 26, 2010 12:07 PM
bhorwhat
Oct 29, 2008 12:55 AM
