Hood Molding or Rubber Weather Stripping?
Old Oct 17, 2011 | 07:58 PM
primey's Avatar
Default Hood Molding or Rubber Weather Stripping?
I was looking under the engine of the disco and noticed what appears to be Hood Molding or Weather Stripping (Rubber Material missing on the vehicle.) I don't know the proper name for it, but it appears to be what the hood sits down the rubber part is missing. I was wondering if anyone could tell me where I could purchase these strips at to fit. Thanks for your reply and link. Its a Disco 97 SE-7 V-8. Thanks,
Primey
Old Oct 17, 2011 | 08:16 PM
Can you take a pix of the exact area? The parts dismantlers should be able to help.
Old Oct 17, 2011 | 08:31 PM
primey's Avatar
This is not my actual rover, but here is a link to one with the hood up.
http://carphotos.cardomain.com/ride_...006_medium.jpg
If you look to the left of the coolant tank that rail leading up, I was told should a rubber strip on it and the other side as well. I used CTRL + to zoom in with firefox, but I don't see a strip there or the rigt side. The guy told me this use to work a Jaguar. Thanks for your help and my check engine light went off when I found the plug wires that were loose. Thanks,
Primey
Old Oct 17, 2011 | 09:35 PM
Mine does not have rubber on top of the fenders either. There is some around the radiator (closes space between condenser and radiator) and some around the windshield wiper area. I got a hood blanket from a D2, mine did not have a hoodie either when I got it.
Old Oct 17, 2011 | 10:03 PM
EricTyrrell's Avatar
Same here.
Old Oct 21, 2011 | 12:01 AM
mpeters's Avatar
4th Gear
A few years back, I actually bought the under-hood weatherstrips for a DII from the dealer. They fit my 96 just fine, and give way more coverage than what little stripping comes stock on a D1.
/mike
Old Feb 27, 2016 | 01:38 PM
97discovery's Avatar
6th Gear
I recently lost a battle with an automatic car wash! My truck died after the ECU got wet. I came across this thread while searching for ways to waterproof the area...I only had about a six inch piece of weatherstrip on each side toward the cowl.
I'm not sure how much the factory weather-stripping costs, but below is a decent solution. 10 feet was more than enough to wrap both front fenders and to cover up the sharp edges behind the headlamps.
Vertical Bulb Trim Seal Bulb Diameter: 0.55" Flange size: 0.039" to 0.14" ( 10 Feet ) - - Amazon.com Vertical Bulb Trim Seal Bulb Diameter: 0.55" Flange size: 0.039" to 0.14" ( 10 Feet ) - - Amazon.com
Old Feb 27, 2016 | 06:47 PM
TOM R's Avatar
I use the fender weather strip from d2 , junk yard
Old Feb 28, 2016 | 07:49 AM
RedRovin''s Avatar
Same here. Finally got some a couple weeks ago. Not sure if it was supposed to, but it seems to have decreased my intake temp a couple degrees...
hrhoward
Jun 29, 2015 04:06 PM
marjac
Aug 8, 2012 08:03 PM
mcneal
Sep 24, 2007 01:13 PM
Tom Condon
Appearance & Camping Set Ups
Aug 25, 2006 01:34 PM
Tom Condon
Jul 22, 2006 10:56 AM
