Hood Releasing,sort of...
Old Jul 26, 2013 | 11:56 AM
FLA Rover's Avatar
Default Hood Releasing,sort of...
Went out to do tune up and radiator flush only to find my hood wont open. The cable will pull and release, the hood will pop up some but not enough to free it from the latch. Any ideas on how to get it opened and what's catching will help.
Old Jul 26, 2013 | 01:41 PM
TOM R's Avatar
Had this happen just pull up on the hood, the latch is in need of lube (probly)
Old Jul 26, 2013 | 06:45 PM
SSL9000J's Avatar
Rover hood release cables are somewhat famous for seizing up if not lubed regularly. Hood pins are a maintenance free option.
Old Jul 26, 2013 | 07:36 PM
FLA Rover's Avatar
Found the issue to be the safety catch. The cable and release are working fine. The catch is snagging on the opening where it goes into. It somehow got bent forward. Catching at the top of the arm on the pin that holds the spring.
Glen11
Jul 4, 2014 04:03 PM
LADEROUTE
Nov 6, 2012 05:56 PM
00&04 Disco
Aug 10, 2010 10:40 AM
vmann7
May 30, 2009 03:51 PM
GregHaugen
Feb 23, 2007 06:42 PM
