How To Change the Fuel Tank Breather/Vent Hose
Not to hijack the write-up, I just want to add my simple fix for this. I cut the tube where it was leaking from and used a metal cylinder fitting attached to a slightly bigger hose to make a ghetto tube. I got some new clamps, tightened it up and it hasn't leaked since. Not to discredit OP's write-up, but if it is really cold outside, or you really don't feel like dropping the tank, this may work. I'll upload some pictures when I get home.
First post on this forum, since I came across this thread and I am having the exact same issue. However, it seems like the pictures are all broken links, does anyone have a copy or them, it would be greatly appreciated!
Also, did anyone buy the genuine hose? or will any hose do? Mine is a 96 D1
HOSE FUEL TANK VENT DISCOVERY NAS >96, ESR1056 - Rovers North - Classic Land Rover Parts
Thanks!
Thanks!
Hi,
I followed the instructions and worked on my 1997 Discovery 1 this weekend, but got stuck at Step 9 in removing the tank filler hose. I got the hose clamps loosen and was able to slide the big rubber hose off the fule tank filling nose, but found these another smaller tube inside the big rubber hose. It goes inside into the fuel tank and I wasn't able to pull it out.
Do you know what it is? and how should I do to remove it?
Thanks,
Thanks,
I used silicone tape to repair mine temporarily, and it worked well for a few weeks while I waited for an opportunity to do the repair.
