How To Remove Discovery Door Panel Photos
Old Aug 3, 2013 | 08:20 PM
Default How To Remove Discovery Door Panel Photos
The door panels in the Disco are made out of structural foam. On the back are plastic clips that have snap on tips which push into plastic holes in the metal door panel. Use care when prying out, while a putty knife will work, a plastic upholstery tool from parts store will allow you to pry on both sides of the fastener. Makes a popping sound as it comes out (pop-pop-pop-pop). Pull too hard and you rip out the plastic base. Goes back on with a push and squeeze, no hammer needed.
If you have not taken a panel off to work on door lock, window regulator, wiring, or just to find that annoying rattle from parts in the bottom, or sloshing from drains blocked.... you won't "discover" how much damage you can do. Work gently.
Attached Thumbnails How To Remove Discovery Door Panel Photos-p1130515.jpg   How To Remove Discovery Door Panel Photos-p1130514.jpg   How To Remove Discovery Door Panel Photos-p1130513.jpg   How To Remove Discovery Door Panel Photos-p1130511.jpg   How To Remove Discovery Door Panel Photos-p1130510.jpg
Old Aug 3, 2013 | 08:47 PM
fishEH's Avatar
Old Aug 4, 2013 | 11:22 AM
dusty1's Avatar
^agreed, popper is great. i found one at autozone $7 and some change.
Old Aug 5, 2013 | 07:00 AM
gprtech's Avatar
Check out Harbor Freight, they sell an entire pack of them.
daxter1987
Nov 7, 2014 08:27 AM
pottzie
Jul 17, 2012 11:34 AM
Disco Alan
May 13, 2009 12:18 PM
_Chris_
Apr 8, 2009 07:11 AM
orion27
Nov 6, 2008 08:16 AM
