How to reset Service Engine light on a 1997 Discovery XD Camel Trophy Edition
Old May 4, 2013 | 08:08 AM
hriant88's Avatar
Default How to reset Service Engine light on a 1997 Discovery XD Camel Trophy Edition
I have a 1997 Discovery XD Camel Trophy Edition on which the Service Engine red light came on at around 83k miles. Tried to find the reset switch under the passenger side glove box but found this XD version is different from the regular 1997 Disco. Under the glove box I only found a bunch of yellow relayes and the ECU box. No red color reset switch like the DiscoWeb article describes.
Does anyone experience the same before? or can anyone help me to point to the right location where I can find the switch?
Many thanks!
Old May 4, 2013 | 08:26 AM
Look for a yellow with pink wire in that area. Reminder unit is above that row of relays.
Old May 5, 2013 | 09:13 AM
hriant88's Avatar
Default Still don't find the one with pink wires
So I looked down the glove box above those yellow relayes, still didn't find the switch that has pink wires to it. Above the yellow relays is a medium size black box that has a blue wire plug to it. Beside it is the ECU box.
Old May 5, 2013 | 09:31 AM
I don't know what to tell you if your truck is wired different that the factory manual, as in "Special Vehicles". Since all this does is turn on a reminder to take to dealer, perhaps get to dash cluster wiring and at connector C221 cut wire 7, which is purple with orange.
The ECU is normally under the hood for that year.
Old May 5, 2013 | 10:54 AM
hriant88's Avatar
Alright, I found the switch. It seemed the previous owner has touched the switch as it was loosen hidden under the back of the ECU box. It was a 83K Emmision Maintenance Reminder(AMR 5551 from TRW). inside it has a 3-pin connector instead of 2-pin as the DiscoWeb article described (the very right pin is obviously emtpy not connected to anywhere. So I shorted the left two and got the Service Engine light off..
The funny part was that on this switch box, there were actually two holes at the top. So if you just punch through the middle hole and try to reset, it won't work as nothing was down there. You have to use the other hole little bit toward the right side to do it. I actually opened up the switch box and found this. It's the dealer's other way to fool people I guess..
Anyway, thank you so much for the help!
Old Apr 17, 2015 | 06:10 AM
thearmlesswonder's Avatar
Talking
I saw this and it got me thinking .... I just unplugged the whole thing and the light went away. I happy now LOL Maybe someone eles has said the same thing, but I have not seen the post. Thanks guys for turning on to this.
Old Apr 21, 2015 | 05:37 PM
mr4x4's Avatar
hi, heres the way i got my service light out.
Pop off the passenger side panel, below the glove box
Up in there you will see a red or orange box
i think you already found that
anyway instead of completely removing it you can poke a small piece of metal though both holes (alan key) while the box is still connected to you car
this gives the box power and enables you to touch two pins together to reset it periodically.
Roflcopter
Jun 26, 2014 08:40 PM
Fordtech
Aug 27, 2013 08:00 PM
AndreaRoss
Aug 4, 2011 10:37 PM
xb70valkarye
Feb 4, 2008 06:03 PM
billstown
Nov 29, 2006 07:50 PM
