how to setup adjustable panhard
Old Apr 1, 2015 | 08:36 AM
TOM R's Avatar
Default how to setup adjustable panhard
OK I looked around and is there some actual directions how to center the axle and adjust the bar? Just got a tf one
Old Apr 1, 2015 | 09:05 AM
dusty1's Avatar
diy for me = straight edge touching top and bottom of tire while extending up on fender. measure from fender to edge adjust accordingly.
Old Apr 1, 2015 | 09:48 AM
MM3846's Avatar
yup. with tires on the ground.
Old Apr 1, 2015 | 02:23 PM
TOM R's Avatar
um how do you know that's gonna work, fenders can be bowed damaged etc.
Old Apr 1, 2015 | 02:28 PM
dusty1's Avatar
Then run straight edge above fender and measure from hood edge. If on level surface , plumb bob off the frame
Old Apr 2, 2015 | 06:37 AM
MM3846's Avatar
are they? For real though, .5" isn't going to make much of a difference.
Old Apr 2, 2015 | 06:47 AM
fishEH's Avatar
Really? Then why bother with an adjustable panhard at all? As you lift the truck the axle pulls drivers side, but not that much. Tom will probably end up only extending the panhard .5"
I agree with the plumb bob on the outside of the frame rails.
Old Apr 2, 2015 | 08:08 AM
TOM R's Avatar
I looked on several rover sites and there are plenty of ideas, make it same length as drag link, set on level ground and the springs will line everything up just extend the bar to fit etc.(I did this one)
Yes fish I probly only have the bar extended like 1/2" or so, no my fenders are not bent just looking for better solution then judging off sheet metal
Only did it cause price was good and I may go up an inch later, plus I got a hwy vibration in front wanted to see if this fixed it
But laying under truck I think my pinion angle is more of an issue
Glasshaus
Dec 24, 2014 07:01 PM
coors
May 2, 2013 01:22 PM
honda50r
Feb 15, 2013 10:47 AM
coors
Jan 30, 2013 02:25 PM
baddoggyyy
Jan 3, 2007 01:33 PM
