How to use the shifter on your transfer case
Old Oct 13, 2017 | 12:25 AM
deer4011's Avatar
Sometimes these gears dont just drop right in. I think its safe to add that you can roll forward SUPER SLOW then shift the trans into neutral and then shift to desired gear on the transfer case. AGAIN SUPER SLOW like barely rolling or you can get out and rock your truck around...if you want.
Old Jan 7, 2020 | 11:58 AM
Snow Rover's Avatar
My 96' does not move when I shift forward and to the right. Only revs engine when I hit the accelerator. All other positions work. Any ideas?
Old Jan 8, 2020 | 08:22 AM
WaltNYC's Avatar
forward-right is low gear, unlocked. You are 'stuck in neutral'. Without somewhat regular use these things often get corroded/funky and need a little lube to get them unstuck. I'd get under the truck and spray something like WD-40 all over the top of the xfer case. The fact that the lever moved to neutral is actually a good sign.
TRIARII
Dec 29, 2011 07:13 PM
s10lowrider1994
Dec 1, 2011 12:14 PM
Bluesideup
Nov 24, 2010 09:41 PM
workinghard1713
Apr 3, 2010 08:28 AM
texmanmoore
May 5, 2008 07:52 PM
