Idle surge when cold
I ran some tests yesterday;
- I hooked a fuel pressure gauge and got a reading of around 38 PSI with ignition on and while cranking and around 30 PSI while running. Both of the results seem right if I remember right from previous posts on fuel pumps and fuel pressure. However I noticed that fuel pressure will gradually decrease over time if I don't crank.
- I also checked the OBD codes;
P1317 (I searched for an hour without clear answers about how to clear this one - I took the ABS fuse out a while ago)
P015... B2 S2 faulty ( post cat sensor, nothing to do with air/fuel mix)
P1508 IACV open circuit; I bought and installed a brand new IACV at CarQuest, still have the code.
-Rechecked continuity in the harness between the ECM and the IACV, checked out good on each 4 wires.
I'll send it to the shop this week so my brother can scope it to see if the ECM sends a signal to the IACV to open, it closes properly but doesn't open.
helencarmen5
Jan 22, 2012 12:56 PM
schwaggy
Mar 21, 2011 08:57 PM
sesese
Aug 9, 2009 02:23 PM
