IDLE trouble
Old May 16, 2011 | 08:21 PM
Yes I do Danny.
Old May 18, 2011 | 08:35 AM
rover11's Avatar
I had a similar issues. It was the exhaust.
Old May 18, 2011 | 10:50 AM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Exhaust??? You mean the o2's. I'm not experiencing any check engine light. My exhaust system is fine. No, I'm expecting perhaps a diode or a particuliar bad spot in the circuit board on the ECU. I checked out this (new) swapped ECU by connecting a known bad MAF. Sure enough the ECU picked it up as bad. So I assume everything is fine now.
Old May 18, 2011 | 12:30 PM
rover11's Avatar
No I mean the actual exhaust. If you are not getting the correct back pressure the ecu will try and compensate causing the idle to fluctuate. If that is the problem you are having it will only get worse if not fixed. My idle would continue to raise until I put it in reverse or drive. I'm not saying this is your problem but if nothing else works it's worth looking into. Mine was an issue with the muffler but there have been other members on this forum who have had the same problem but it was their cat.
Old May 18, 2011 | 02:01 PM
LRD2&ME's Avatar
No not even close, but thanks.
Old May 18, 2011 | 04:00 PM
Spencerfitch's Avatar
Try Leaving the tps connted but unbolting it.. If it idles correctly it's your adaptive mem
wick_60010
Nov 22, 2017 04:25 AM
KGN96discoSE7
Sep 23, 2017 07:23 AM
scottmb23
Sep 17, 2014 05:54 PM
Matt_Attack352
Jan 13, 2014 09:55 AM
westernsun
May 27, 2006 04:24 PM
