ignition light ring is always on
Old Jun 25, 2014 | 08:43 AM
fishEH's Avatar
Originally Posted by MM3846
the ring turns red when you are in park or neutral... or at least thats what mine does. but it only works when the shifter illumination is working, which is not very often.
Actually since I've started digging into my 95 i have noticed the shifter illumination bulbs are ON anytime the key is on.
Need some info here. Is the ignition ring always lit with the truck on? Does it remain lit with the truck off even after the interior lights have gone out?
Old Jun 25, 2014 | 09:10 AM
MonteroMan's Avatar
Default Who knows...
My vehicle is manual shift and the light never goes out, I've sneaked up on it at night wearing my best camo and it sits just there glowing. Fool thing.
Old Jun 25, 2014 | 10:31 AM
MM3846's Avatar
mine havent worked since the last time i tore into the center console... which is about 2 weeks ago. i cant give you a straight answer. i think the key ring lit when i disarmed the truck w the remote, as far as anything else im not sure.
unplug it.
Old Jun 25, 2014 | 12:01 PM
MonteroMan's Avatar
Default Make the symptom disappear
unplug it.
Gee, one would rather find the cause and fix that - but in the Landrover electric and electronic (dis)array this is not easy.
Old Jun 25, 2014 | 12:04 PM
MM3846's Avatar
yup. sometimes the effort /= the issue. i havent tracked down my shifter lighting issue, nor my rear wiper/defroster issue.
dcox1974
Dec 16, 2016 08:03 PM
TRIARII
Oct 17, 2013 02:02 PM
xtina01
Aug 9, 2012 11:22 AM
tango123
Mar 5, 2009 05:26 PM
