Cargo door not opening from outside
Old Jun 25, 2014 | 08:09 AM
97GreenMeanie's Avatar
Default Cargo door not opening from outside
Before anyone suggests it, Yes, I popped the emblem off and sprayed the hell out of it for several days without any changed.
I popped the panel off on the interior and was able to get the door open and there is a metal linkage or spring broken and/or missing from the outside door handle assembly on the inside of the door.
The handle has functioned without issue since I got it up until a couple weeks ago. Then it felt like nothing was happening when you tried opening it from the outside handle and apparently the child-resistant lock was also enabled, making it tricky to open from the inside without pulling the panel.
Does anyone have a photo or diagram showing how it "should" look?
Thanks!! Any info is much appreciated!!
It's a 97 Disco I with power locks (which work fine)
Old Jun 25, 2014 | 08:48 AM
jafir's Avatar
I'd think you'd be able to get a used handle pretty cheaply.
A new one isn't about about $50
Door Handle - Outer - Rear Cargo Door (Genuine Part # CXB102190 ) - Land Rover door catches\window regulators from Atlantic British
http://landrovermerriamparts.com/par...&siteid=215719
http://www.partswebsite.com/landrove...CXB102190.html
According to their website it's in stock here:
http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
Old Jun 25, 2014 | 09:35 AM
Thanks for the links and info.
The outside door handle itself appears to be functional.
I don't think it needs replacing.
The part that is missing/broken attaches to the tab on the inside of the (outside) door handle and releases the latch allowing the door to open.
It may be as simple as a spring or threaded rod.
I don't know what it was supposed to be because nothing is currently attached to it.
Old Jun 25, 2014 | 01:31 PM
ajnolin's Avatar
Rave has a decent exploded view of this assembly, helped me muddle through my rear latch issues
cobbcj7
Sep 30, 2014 10:38 AM
ToddD
Jun 24, 2012 09:14 AM
