induction cleaning question
Old Jun 11, 2013 | 06:12 PM
Lord Wert's Avatar
Default induction cleaning question
where do I need to suck in the seafoam from. the oil separator tube?
Old Jun 11, 2013 | 06:56 PM
jastutte's Avatar
i always use the hose coming off the throttle body just above the IACV. unplug it from the driver's side valve cover, twist it around so it faces up and slowly dump in the Seafoam. a small funnel helps.
Old Jun 11, 2013 | 08:59 PM
Rover75's Avatar
4th Gear
I've used the oil sep tube, use some pliers to squeeze the hose so it doesn't suck it to fast and stall the engine.
Old Jun 12, 2013 | 12:48 AM
This is what is inside the intake. If you have too much gunk, from plugged up PCV system and previous owners that did not maintain things, then you may have more than Sea Foam can handle. I have SeaFoamed at least four times. This is what I found when I started the HG job. The PCV line is that bottom left.
Old Jun 12, 2013 | 01:05 PM
Lord Wert's Avatar
Smile
you guys are awesome. ill report back asap
Old Jul 22, 2013 | 04:36 AM
Delboy21's Avatar
I just had oil changed about 500 miles ago and then used seafoam treatment in my crankcase. Do I now need to change out the oil again??
Old Jul 22, 2013 | 08:33 AM
Your choice. Depends on how dark oil looks. If still clear the filter is getting the gunk.
ChanchoVerde
Apr 18, 2010 09:34 AM
KeizerRover
May 11, 2008 10:31 AM
armyproud
Apr 25, 2008 07:44 AM
Phototone
Apr 23, 2008 07:48 AM
Scanner
Mar 24, 2008 02:10 PM
