Installing aftermarket stereo, very little noise coming out of speakers
Old Nov 19, 2013 | 10:05 PM
christiansmith6's Avatar
Default Installing aftermarket stereo, very little noise coming out of speakers
So I'm installing an aftermarket stereo into my 1996 Disco and I'm having some issues....
I have the new stereo hooked up to the speakers and the AMP correctly, but whenever I try to play music through it I have to turn the volume up all the way to get any noise at all! Anyone have any idea what could be the problem?
Old Nov 19, 2013 | 10:07 PM
dusty1's Avatar
crank it up, man.... is the amp working?
Old Nov 19, 2013 | 10:21 PM
Frankly dusty1 I don't know enough about it to even know how to test it.
Old Nov 20, 2013 | 07:07 AM
jdhuegel1's Avatar
It sounds like you incorrectly wired the speakers trying to use the stock amp. Bypass the stock amp. It's crap anyway, and if you're using a stereo made in recent years, chances are you've got enough juice to power the components anyway.
Old Nov 20, 2013 | 07:17 AM
jdhuegel1's Avatar
Originally Posted by calebbo
amp bypass walk through:
what you will need:
about 12 feet of speaker wire (16 to 12 gauge will work although 12 is harder to run through the dash, also pick a speaker wire that you can easily tell polarity I would suggest a red and black set)
electrical tape
wire stripper and crimper (either all in one tool or 2 separate tools)
at least 8 - blue T taps ( and maybe a small pair of pliers to close these)
at least 8 - blue male spade connectors
at least 11 - blue butt connectors
handful of zip ties for a cleaner install (the zip ties are optional)
you can get all of this at Walmart
step 1: remove the radio, remove the glove box, locate the amp and unplug the plug/harness.
step 2: hold the plug in hand (do not let go until the next step) and locate the 8 speaker wires in that plug. The 8 wires should be as follows:
Black/Brown = left front -
Black/White = left front +
Black/Red = right front -
Black/Pink = right front +
Black/Orange = left rear -
Black/Yellow = left rear +
Black/Blue = right rear -
Black/Green = right rear +
each set of speaker wires will be twisted together a couple inches from the plug (for example the black/brown wire and black/white wires will be twisted together for the left front speaker)
step 3: you can now let go of the plug. Crimp the T taps on to each of the above wires roughly 4 inches from the plug that was just in your hand. (these wires may all be wrapped up together a few inches from the plug, just try to remove a few inches of this wrapper)
step 4. cut your speaker wire into 4 equal lengths of 3 feet each. Label each length LF,RF,LR, and RR at each end with some masking tape (see step 8). (if you have the zip ties you can zip tie the 4 runs of wire together into 1 thick run of wires)
step 5. crimp the male spade connectors to one end of the 8 speaker wires
step 6. connect the male spades to the T taps be sure to align your labels to there corresponding wires. (example your front left labeled wire will be attached to the black/brown and black/white wires).
step 7. run the other end of your wires up through the dash to the back of the radio. this will take some time, and I will warn you there is nothing safe behind the dash, I have drawn blood about 75% of the time doing this part of the job! you may find using a straightened metal coat hanger will help you run these wires where your hands can't get.(when your done, zip tie the wires clear of moving parts like the glove box and heater cables)
step 8. determine what wire is what at the loose ends of your new speaker wires. Hopefully you labeled them correctly, if not you will need to "pop" the speakers with a AA battery (hopefully you won't need to do this but if you do I will walk you through it)
step 9. connect your new wires to the wires on the back of the aftermarket radio with the blue butt connectors.
aftermarket radio colors are as follows:
white = front left +
whit/black = front left -
gray = front right +
gray/black = front right -
green = left rear +
green/black = left rear -
purple = right rear +
purple/black = right rear -
you can use your Metra harness for the yellow, red, and black wires (power wires).
step 10. connect the antenna and test, if it works then install the radio in the dash and put everything together.
From an old thread.
Old Nov 20, 2013 | 10:01 AM
WaltNYC's Avatar
tell us more about HOW your installed the new stereo. did you use the metra wiring harness? did you run new wires to your speakers?
There are 100's of ways to install a stereo so a bit more background is helpful.
Old Nov 20, 2013 | 11:44 AM
wrongway1's Avatar
I just started having the same issue with my factory radio. Have to turn it up full blast on the dial just to hear the darn thing. If you figure it out, let me know. Was thinking it was the amp, but haven't messed with it yet.
Old Nov 20, 2013 | 08:39 PM
abran's Avatar
Wrongway1- For your stock stereo, maybe its the volume switch on the side of the gauge panel? I had someone use it on my car,then the switch went out. Replaced it and now I can adjust volume on the dash or the **** with full volume restored.
Good luck.
Old Nov 21, 2013 | 12:57 AM
Alright everybody sorry it's taking me so long to get back. The amp had gone bad, so I rewired it using the instructions posted earlier in the thread. It worked perfectly. The only thing is I'd cut the pieces of wire a little longer than 3 feet to give yourself a little more slack and maneuverability when running it up through the dashboard. The amp bypass was a success and the stereo sounds great. Thanks everyone for the help and suggestions!
Old Nov 21, 2013 | 09:18 AM
dipdgarage's Avatar
I am having trouble with mine too! I installed my new radio and no problems other than when i turn it on, the radio has a noise (almost like a ground noise but i grounded to frame) then if i turn ignition off and leave on accessory it works perfect. What do you guys think?
