Installing puddlelights in front doors
Old May 16, 2020 | 01:03 AM
Icannap1's Avatar
It looks like the light you want to install has two conductors easiest would be to run a pair of 18 ga. 2 conductor speaker wire into the front doors and connect the light on that end, then on the other end run it up the A pillar to the overhead dome light 2 conductor connector and you are done. As for the rear door run a pair of 18 ga. 2 conductor speaker wire into the rear door and connect the light on that end then on the other end run it to the rear dome light located by the rear door jamb. You will need to run the 2 wires the (+) positive is timed and will turn off if the door is left open for more than 10 minutes I think and controlled by the module behind the fuse box under the dash by the steering wheel and the (-) negative is a combined trigger from the remaining doors.
Old May 16, 2020 | 06:02 AM
Toran's Avatar
At last the weekend has arrived and I can return to the site. I missed the images as I was looking at this thread via an old phone browser that didn't properly load the images. Now that I see the images I am going to echo the directions from Icannap1, should be very straight forward.
I would like to see these in action when your install in complete.
Old Jul 26, 2020 | 03:33 PM
Saimein's Avatar
8th Gear
Followed the instructions about wiring them into the dome light. Ran the wires down the A pillar and into the door. They work great! Pulled these off of a Range Rover Classic.
Puddle light is actually bright enough to be useful at night.
Drivers and passenger door all work and light up when opened. Haven't figured out how to wire the rear cargo door. Not sure if any ever had one there but there but there is the same blanking plug and the light fit right in. Planning on wiring this up to the rear dome light when I pull the headliner in the future.
Old Sep 1, 2020 | 03:56 PM
Pierrodisco's Avatar
Usefull help, Saimein !
Now I’ have -finally- tile to install the puddlelights, but just one problem :
All lights and switches are DC, what means to respect the polarity (+ and -) from all the lights. So my puddle lights have a Purple-White and a Purple-Orang wire. Which of them both connects with te Purple-Brown wire and which with the Purple-Blue wire of the front doom courtesy light ?
I think it really matters !
Greetings,
Pierrodisco
Old Sep 1, 2020 | 05:40 PM
Toran's Avatar
Congrats on the install, looks slick.
Good light coverage at night?
Old Sep 1, 2020 | 11:20 PM
Icannap1's Avatar
Yes all vehicle wiring is DC. If the puddle lights are regular bulbs then the polarity will not matter as it is just a coil element if it is led then it will matter but if you connect it wrong it will not harm anything it will just not light up if connected in the correct polarity it will light up.
Old Sep 2, 2020 | 03:57 AM
Question Polarity when changing “classic” bulbs in LED’s
Hello,
Thus no problem at all if connecting puddle lights with “classic” bulbs. Looks fine!
But no problems about the increase of total amount of wattage for the fuse ?
And how can you “masure” the polarity on the fittings/connectors in case of changing the classic bulbs by LED’s ?
Greetings,
Pierrodisco
Old Sep 10, 2020 | 01:54 PM
disco96sd's Avatar
curious as to WHY you wanted to do this ? lots of rain in your neighborhood ? bad gutter draining in your city ? or just an idea to improve on the original ?
Old Mar 4, 2021 | 06:38 AM
Hello Disco96sd,
indeed !
Just as idea to improve on the iriginal !
Much greetings,
PierroDisco
Old Aug 22, 2021 | 07:36 AM
Smile Disco 1 Connecting rear door puddle light to cargo light
Hello,
For replacing the small broken retaining spring in the tailgate lock, the inner panel of the rear door was taken completely off. So ‘I decided to place the red puddle light in the rear door. I connected both wires not to the rear dome but to the cargo light (much easier because much nearer !). The hole after both grummets in rear door and quarter panel can be passed in one time, using a small soft plastic tube on which you firmly tapes both conducts.
Real upgrading !
Urban Panzer
Dec 6, 2021 12:25 PM
Geo
Mar 14, 2020 02:11 PM
Jeff Blake
Aug 9, 2017 10:47 AM
97LANDISCOVERY
Sep 12, 2007 08:36 PM
GMachineFAB
Dec 29, 2006 01:57 PM
