Installing a Spal fan...
Hmmm, I do electric on vehicles that don't go in water all the time, mainly because I hate fan clutches and believe in my head that the power loss from the additional load on the alternator(as long as it doesn't max out the alt.) was less then the load the mechanical fan placed on the engine. But you could always install a master switch to turn off the fan for water crossings and still have it set up with a thermostatic on-off and variable speed.
remove your fan and find out exactly how much it helps. Not much untill its hot outside and not really any if your moving.. The electric fans only turn on when you want them, even then the load on a alternator has to be more efficient. Your turning that fan [even if it is slipping] while your cruising 30-70mph. Completely unnecessary. And last but not least. Less wear on water pump
All the thermo switches I have used are preset to engage at a specific temp. Dual thermo will have a low and high trigger. IE 4 wire thermo switches.
Of course I am referring to what I have used most of my life which are on VW/ Audi's
and would be cool to see...I've only seen vehiocles do that in mud. But besides that, mud will be the death of a fan, whether mechanical or electric. But both are waterproof...at least, Spal claims to have waterproof motor housings for their fans...but if I ever got my vehicle in that much water, I'd probably kill the engine until I could get it out and dried off...do you know any history of that pic?
http://www.cameltrophy.co.uk/history/1985.htm
You can get kits to 'tap' into your existing ect signal wire or install an additional ect on the head or block and use a control module to toll the e-fan when to turn on, off, and to have a variable speed.(spins slower at low temps on up to max speed for max cooling.) Then you can add a master on-off switch for water crossings if you wanted to.
twilightcall
Mar 4, 2018 06:55 PM
rover1978
Sep 26, 2009 09:05 PM
