Intake gasket replacement
I am new to Rovers, and I just bought a 98 Discovery. I am a master Audi tech, but I have never worked on Rovers. I know that the intake/valley pan gasket is leaking. I found a website that sells a kit that includes the intake gasket, end seals, and valve cover gaskets. However, it doesn't include the plenum chamber gasket which I understand is just high-tack sealant. I also want to change the valve cover gaskets, but what is Bostik 1775 impact adhesive? Do I need this? What sealant should I use on the intake "end gaskets?"
I would just get some gasket maker from autozone
You can also find all of the gaskets you need on ebay ....they are same as those from dealer...
Sure, sometines I put that gasket maker on both sides of a gasket just to make sure nothinh will leak... or when old gasket is still ok and I want to reuse it
