Intake gasket replacement
Old Apr 4, 2011 | 01:23 AM
Danny Lee 97 Disco's Avatar
Originally Posted by tibyABv6
Sure, sometines I put that gasket maker on both sides of a gasket just to make sure nothinh will leak... or when old gasket is still ok and I want to reuse it
And you think that just because you did it and got away with it that makes it the best way to do it?
Old Apr 4, 2011 | 05:37 PM
tibyABv6's Avatar
yes.....this stuff is meant to be used as a gasket material between two flat surfaces, and something you would want you use or can use instead of gasket between intake manifold and intake manifold "lid" or between intake manifold and plenum chamber.
Also used for oil pan on the cars that use a silicon gasket.....can be used instead any thin flat gasket or on both sides of a used thick gasket (since when you reuse gasket the deformation that ocured from first use will not identically line up)
TOM R
Jan 24, 2013 05:04 PM
jpmiller
Sep 26, 2012 06:32 AM
teeboli
Mar 16, 2011 09:11 AM
maxellfullmoon
Jul 26, 2010 09:09 PM
