Interestin No Start Problem Solved...
Old Mar 3, 2020 | 09:56 PM
Cap-n-Cray's Avatar
Default Interestin No Start Problem Solved...
I have a 1995 Discovery 5 speed with 124K on the clock. Great Truck. A few days ago I went to start it and it turned over almost starting, but wouldn't run. I have been looking everywhere for the answer...
Good spark
Fuel pressure well with in specs.
leak down OK.
Injector test out firing fine using a noid.
Replace spark plugs which are wet from fuel.
Measure all voltage points, coil, and pick up, OK.
Check timing.
When I try to start the engine it almost wants to start. Tail pipe smells of fuel. I decide to check the oil for gas. No smell of gas, but it's 3 qts. low. The truck does like to mark it's territory, but not much. No smoke on start up or when running. It has been down 1 qt. before when I changed the oil every 5K...
I put 3 qts. in and the truck starts right up like nothing ever happened...
Old Aug 12, 2020 | 06:55 PM
Toran's Avatar
Five months later, is the truck still running back to normal?
Old Aug 13, 2020 | 01:33 PM
Cap-n-Cray's Avatar
My Discovery is running great with no hiccups. I did replace the weak alternator but that was unrelated to the original problem...
I still can't figure it out. I am getting close to an oil change and it will try to see if it will start with 3 qts oown...
I'll post the results...
Old Aug 13, 2020 | 05:09 PM
Toran's Avatar
Thanks for the response.
Looking forward to see what happens.
Josh Barlow
Mar 18, 2021 09:16 AM
vashonrovermechanic
Sep 21, 2011 02:50 PM
2000 Disco 2 SD7
Aug 20, 2008 12:37 PM
robdis96
Apr 18, 2007 11:08 AM
DiscoGal
Oct 17, 2006 03:36 PM
